Does Rhino support the display of images with transparency in render display mode?
If I place a picture frame with a png with transparency, although he scene render fine, however the transparent areas appear white in the viewport display.
+1
PS: Maybe the Serengeti is a better place …
Thanks Micha.
I moved it to “Rhino for Windows”. Isn’t Serengeti for WIP 6? I’m using 5.
You can’t expect any update for Rhino 5, any improvement will be added to v6 only.
I understand. I just thought that this feature existed already in ver 5. Thanks.
Make shure AlphaTransparency is activated in the PictureFrame command options:
First corner of picture frame ( Vertical SelfIllumination=Yes EmbedBitmap=Yes AutoName=No AlphaTransparency=Yes ):
aaaahhh … I never noticed these options before ! Thanks!
