Thanks for the info eddi. But this still gives a very uneven structure which will cause problems with my edge blending.
Is it my inital curve that is the problem?
I think that in these cases, a command such as “Pipe” should solve by itself these kinds of situations. Such a command can not remain equal to that of years ago! We think of a piece of tubing with dozens and dozens of these curved sections: a folly to do this myself!
One way to avoid the problem is to have only rounded corners on the centerline with the minimum radius of the centerline greater than the pipe radius. If a corner cannot be rounded then keep the corner of the centerline sharp, split the centerline at the corner and use the procedure shown by eddi above.
