Hi All,
I am trying to achieve the pipe being narrower in the middle, and wider near the corners. When I use Pipe command with variable radius, I get twists and distortions. When I create a single diameter pipe and then explode and manipulated via control points, the edges/corners come apart, and I need a closed polysolid.
I have done this before with rounded curves, so is it the square corners that are causing disorientation?
The pics below show both methods
Curve:
Any help much appreciated.
Thanks,
