Hi there, i get this error in the rhino console when gh starts up. I am stumped and confused, and kindly asking for your help.
"An error occured during GHA assembly loading:
Path: C:\Users\andrei.ivanescu\AppData\Roaming\Grasshopper\Libraries\humantreefrog\TreeFrog.gha
Exception System.IO.FileLoadException:
Message: Could not load file or assembly ‘file:///C:\Users\andrei.ivanescu\AppData\Roaming\Grasshopper\Libraries\humantreefrog\TreeFrog.gha’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception System.NotSupportedException:
Message: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information."
