For some reason, without a real cause I can think of, I started getting this error in the Rhino Command Line when starting Grasshopper:
Message: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
I tried looking into the error message but all I could find is some corrections potentially to a machine.config file somewhere on my system which I can’t find.
Anyone ran into this issue before?
Thanks
