Hello @eirannejad, I hope you can help me with the problem below.
Yesterday, I did some things for the first time with the new Rhino 8 scrip editor, prompting me to install a couple of things. Today, I discovered that many of my usual Grasshopper plugins can not run, and after a few minutes, Rhino crashes without any report.
Below, I am posting the details of the errors, Also my system info.
Many thanks in advance.
Command: Grasshopper
An error occured during GHA assembly loading:
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\chromodoris.gha
Exception System.IO.FileLoadException:
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\chromodoris.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception System.NotSupportedException:
Message: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See <loadFromRemoteSources> Element | Microsoft Learn for more information.
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\DecodingSpaces.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\DecodingSpaces.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\octatreevoxelisation_0.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\octatreevoxelisation_0.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\Pufferfish3-0.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\Pufferfish3-0.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\SectionBoxGH.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\SectionBoxGH.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\sunglasses.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\sunglasses.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\telepathy.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\telepathy.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\Wallacei_7WIP.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\Wallacei_7WIP.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Path: C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\MetaCityGenerator_v.1.0.1\MetaCityGenerator.gha
Message: Could not load file or assembly âfile:///C:\Users\chriscaceres\AppData\Roaming\Grasshopper\Libraries\MetaCityGenerator_v.1.0.1\MetaCityGenerator.ghaâ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Rhino 8 SR18 2025-4-8 (Rhino 8, 8.18.25098.11001, Git hash:master @ 470807fca55aa69632c599bd41a760b69581d726)
License type: Commercial, build 2025-04-08
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET Framework 4.8.9300.0
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Remote Desktop display device with 16 connection(s)
- Windows Main Display using connection 0
Primary OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-3-2024
Driver Version: 32.0.15.6636
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll âEnscape.Rhino8.Pluginâ 4.2.1.88
C:\Users\chriscaceres\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\23.10.24.0\bullant.rhp âbullantâ 23.10.24.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp âDatasmith Exporterâ 5.3.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp âIronPythonâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.18.25098.11001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
