Plug-in not loading in Grasshopper both Rhino 5 and 6
which could be the reasons why a plug-in is not loading in Grasshopper both Rhino 5 and 6?
The gha file is unblocked and located in the Libraries folder. The plug-in is Syntactic.
Thank you.
Francesco
Solved. In Grasshopper Developer Settings the option Memory Load *.GHA aqssemblies with COFF byte arrays was unchecked. (Probably because required by another plug-in)
