If it takes more than 20 seconds I want to cancel it. But I can’t! Can we please make this command escape-able so I’m not forced to decide between killing Rhino and re-doing work from my last save or autosave, and sitting and watching the spinning blue wheel with no ETA?
i would wish that for every other command either which just takes forever and sometimes does never end.
oh cool!
Guys - how hard could it be to get escapable commands implemented??
Just ran into another Rhino freeze on a simple mesh object MeshOutline… took good 10 minutes for Rhino to get responsive again…
It was “Open” for Rhino V6 back in 2016… We passed V7, now I see it is slated for V8. Really?
Esc-cancelable commands are a mixed bag in Rhino now, having this ability is a must and a life-saver on those that have it implemented. Could this get a higher priority please? IMHO this is Rhino’s one of the biggest simple productivity drawbacks. There is probably several RH items open for different commands… So take this as a general comment for allowing Esc to cancel any of Rhino’s processing-intense commands.
thank you
–jarek
To reply to my own post… here is a good example of why this is needed, at least until the command does not fail on a relatively low-poly mesh (yes, it’s a bit messy).
Here is the example file - for a good Rhino freeze please try running MeshOutline from the Top view:
MeshOutline_Problem.3dm (624.2 KB)
By the way, looks like there are 4 concurrent YT items for the same request, dating from 5 years, 2 years, 6 months and 2 weeks ago…
@GregArden - making sure you are seeing this. Thank you.
EDIT: this sample file took 1.5h to complete MeshOutline on a fast workstation. We would never wait that long if the Esc/Cancel was available but the problem was losing the work done prior to running this command.
–jarek
Jarek,
I’ll move it up the priority queue.
