- for some reason the lofted surface isn’t following the closed curves of the tower floor plates. I’m pretty sure I selected the bottom and top curves correctly for the surface to loft through, but I’m getting this weird twisty surface that doesn’t follow the curves.
- the second problem has to do with connecting the facade to the floor plates. From what I understand, you simply construct a domain to choose what parts of the tower you want to get covered. The problem is that even if i made the domain and selected the floor plates that i wanted to get covered the facade doesn’t completely cover the entire area. So i have gaps between each loft section.
I included my grasshopper file and you can find really big panels to find the problem areas in the code.
I’d really appreciate some help to fix these issues!
A04 - V02.gh (101.0 KB)
Thank you,
Daniella (confused architecture student)
