PlanarSrf Split with Closed Brep - accuracy issues (Rhino 6&7)
Hi all,
Does anyone know why the following script doesn’t work in all locations? In most of them it does but there are locations that simply doesn’t work
For this example i have used the following file but it happens also in other models that i have tested.
Edit: I have some issues uploading the file and screenshots.
contour_srf.gh (453.9 KB)
Hi -
I don’t know why, no. I’ve put it on the list as RH-62377 to be looked at.
You can work around this by using the Brep | Brep intersection component and creating a surface from that intersection.
Thanks @wim,
FYI I can reproduce the same issue in 2 other shapes i tested.
@wim
Furthermore, i noticed that when offsetting a curve that has been created from contour command the direction is not consistent.
contour_srf2.gh (453.9 KB)
Any idea that can be a work around for the moment would be nice
Thanks
What @wim suggested above is to use Brep / Brep instead for the time being like the attached…
contour_srf2_re.gh (461.6 KB)
