I’ve run into an issue while trying to split a set of closed curves with a plane. The output consists of only partially split curves.
Interestingly enough, if you move the reference curves the output will vary. You can even get all of them to split, but moving the curves is not something I plan to do in my usecase.
Only just starting get a grasp of Grasshopper so I’d appreciate some help or advice to remidy this, thanks!!
The issue happens regardless of seam position it seems. Curiously the amount of correctly split curves changes with increased spacing between the curves. It seems very arbitrary.
