Plan View Reference Changes When Switching Active Viewports
I’ve noticed another issue with VisualARQ Plan View References when working with multiple viewports.
When the Top – Level 01 viewport is active, with the Plan View Reference enabled for Level 00, the reference is displayed correctly.
However, when I switch to the Perspective viewport, the Plan View Reference in the Top viewport changes, even though no geometry or level settings have been modified.
As soon as I activate the Top viewport again, the correct Plan View Reference is automatically restored.
Expected behavior:
The Plan View Reference should remain consistent in the Top viewport, regardless of which viewport is currently active.
Actual behavior:
The Plan View Reference changes depending on the active viewport.
This makes working with multiple viewports unpredictable, particularly when using floor plans for architectural documentation.
I’ve attached screenshots showing the difference between the two states.
Hi @badileanu You are right, this is how it used to work before but it changed in some VisualARQ update. We will revise this.
Thanks, Francesc!
Good to know this is a regression. I appreciate you looking into it!
