Pixellated large Mouse Pointer - Rhino 8 - Windows 11
Windows 11 - Rhino 8 - Quadro RTX4000 - Logitech G102 mouse:
I set Windows to use an enlarged mouse pointer on my 4k screen otherwise the mouse pointer is tiny. For quite a few months now I have been seeing the odd mouse behavior detailed below once I open Rhino 8. I thought a Rhino update might fix it but no joy to date.
Once I open Rhino 8 the mouse pointer keeps its large size, but becomes visually distorted. This then keeps this distorted look not only in Rhino but in all other Windows operations until I close Rhino 8. Then the mouse pointer becomes tiny and pixellated (Throughout Windows 11). I then have to go back into Windows 11 mouse settings and move the size slider. This instantly resets the mouse pointer to look non-pixelled and large again as normal.
This has occurred for a few months with various different mice/nvidia drivers/Rhino8 updates.
From my observation Rhino8 is somehow changing how Windows 11 mouse looks with a global setting?
Perhaps there is a simple fix for this? Michael VS
I am also having the same issue. Here is my system’s data:
Rhino 8 SR25 2025-11-10 (Rhino 8, 8.25.25314.11001, Git hash:master @ 305475a429872768e321960d34ed215b72a0da18)
License type: Commercial, build 2025-11-10
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.14
Computer platform: LAPTOP  - Plugged in \[100% battery remaining\]
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-27-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.09
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-27-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.09
Secondary graphics devices.
AMD Radeon™ 890M Graphics (AMD) Memory: 1GB, Driver date: 4-11-2025 (M-D-Y).
> Integrated accelerated graphics device with 5 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-27-2025
Driver Version: 32.0.15.7309
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\\Program Files\\Chaos\\V-Ray\\V-Ray for Rhinoceros\\V8\\VRayForRhino.rhp	“V-Ray for Rhino”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCAM 2025 for R8\\RhinoArt1FileExporter For Rhino8.0.rhp	“RhinoArt1FileExporter”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCAM 2025 for R8\\RhinoCAM 2025 For Rhino8.0.rhp	“RhinoCAM 2025 - The cutting edge CAM plug-in for Rhino 8.0 from MecSoft Corporation”
C:\\Program Files\\Bongo 2.0 (64-bit)\\Rhino6\\Bongo.20.rhp	“Bongo 2.0”
C:\\Program Files\\Rhino 8\\Plug-ins\\Commands.rhp	“Commands”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\WebBrowser.rhp	“WebBrowser”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk.rhp	“Renderer Development Kit”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoScript.rhp	“RhinoScript”
C:\\Program Files\\Rhino 8\\Plug-ins\\AnimationTools.rhp	“AnimationTools”
C:\\Program Files\\Rhino 8\\Plug-ins\\IdleProcessor.rhp	“IdleProcessor”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRenderCycles.rhp	“Rhino Render”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRender.rhp	“Legacy Rhino Render”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk_etoui.rhp	“RDK_EtoUI”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\NamedSnapshots.rhp	“Snapshots”
C:\\Program Files\\Rhino 8\\Plug-ins\\MeshCommands.rhp	“MeshCommands”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCycles.rhp	“RhinoCycles”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\Toolbars\\Toolbars.rhp	“Toolbars”	8.25.25314.11001
C:\\Program Files\\Rhino 8\\Plug-ins\\3dxrhino.rhp	“3Dconnexion 3D Mouse”
C:\\Program Files\\Rhino 8\\Plug-ins\\Displacement.rhp	“Displacement”
C:\\Program Files\\Rhino 8\\Plug-ins\\SectionTools.rhp	“SectionTools”
I’ve run with an enlarged mouse pointer for some time and never seen this, but you have plugins that I don’t. What happens if you temporarily disable the “do not ship with Rhino” ones?
Regards
Jeremy
I tried removing all the plugins that are not shipped with Rhino, but that did not solve the issue. Also, I noticed the more instances I open, the more pixellated the pointer becomes. It also gets very small when I close Rhino.
Hi @Jason_McCloskey,
Is your 4K screen external? If so, is it set as your primary monitor? If not, can you set it so?
– Dale
Rhino 8 also has some conflict with a screenshot program called Gadwin printscreen. Once Rhino 8 is started (even before the full loading), it evokes the pop-up menu of Gadwin printscreen. The same goes for when the Properties or Rhino options panels are opened, or after various other operations.
Rhino 7 does not exhibit that bug.
Dale,
The 4K screen is my laptop screen. I did try changing it back to it being the primary monitor, but that did not fix the issue.
