So I switched over to Rhino6 a couple of weeks ago. One thing I recall is that I could select an object and then when I rt clicked to pivot the view around it would pivot around that object. Is that an option or am I dreaming?
Hello -Zoom Selected will place the camera target in the center of the bounding box of the selection and the view will tumble around that point. Also, Zoom Target will set the camera target to a specific location. If Gumball is on, you can set the view to rotate around the gumball (Gumball settings)
Any of that help?
that’s it, rotate view around gumball, thanks
