Pivot point for turntable animation
How do I set the pivot point for a turntable animation in Rhino 6? I want my model to pivot around its central axis.
Hi Richard -
From the help file:
The SetTurntableAnimation command animates the camera rotation once around the current target point. […]
If setting the target doesn’t get you what you want, perhaps you can set up a path animation instead?
How do I set a target point?
Hi Richard -
You could use the Place button in the Properties panel:
Zoom Target will also set the target, and you can show the camera with the Camera command and manually select and move the target point.
Yes. Thank you. Setting camera location and target in viewport properties did the trick.
How it finished up.
