hello,
i have a little probleme, i cant pipe 3d curves
a 2d is no probleme but i need this curves to pipe
i hope you guys can help me.
i upload the file with the curves i cant pipe …
3d curves to pipe.3dm(628.4 KB)t
hello,
Hi Micha,
I can pipe it here, yet probably not the diameter you were trying?
What radius did you try? (2 works here)
Another thing: If you need this just for rendering/visualization purposes, you might want to consider and use the applycurvepiping command instead:
http://docs.mcneel.com/rhino/5/help/en-us/commands/applycurvepiping.htm
HTH
-Willem
hi thanks, i upload the wrong file the curves are 2d
here are the type of cruves i like to pipe,
the idea wir applycurvepiping ist great but i render with v-ray.
here is the new file with an 3d curve i like to pipe
curve to pipe.3dm(325.7 KB)
You can still use ApplyCurvePiping and then extract the render mesh for rendering in vray.
(not on a computer now so I can’t try your new curves…)
Hi Micha,
That curve I can Pipe as well:
Wim’s suggestion of extracting the piped curve is a good workaround.
use the command ExtractPipedCurve to create a mesh object from the piped curve after applying ApplyCurvePiping.
HTH
-Willem
thanks it helps a lot
