Curve piping output
Hello all,
I just found the ApplyCurvePiping command to turn wireframes into pipe networks. I like the look of this, but is there a way to get this new 3D geometry into a solid or mesh to further manipulate? I realize curve piping is a render effect, but once I adjust the properties to my liking, I’d like a working model out of it.
Try ExtractPipedCurve
Sam
Ahah! I wish they would put useful related commands on the documentation page: https://docs.mcneel.com/rhino/5/help/en-us/commands/applycurvepiping.htm
Thank you!
Just making sure @margaret sees this.
Hi, All,
Thanks, Wim,
In a couple of hours, take a look at the Rhino 6 Help: http://docs.mcneel.com.s3.amazonaws.com/rhino/6/help/en-us/index.htm#properties/curvepiping.htm
I keep adding more and more cross-references. Tell me when you see one that will help you. It’s not going to happen in Rhino 5, though. Just going forward.
OK, ExtractPipedCurve is there now, but not ApplyCurvePiping:slight_smile:
You mean, not updating Help for R5?
// Rolf
ApplyCurvePiping is not a command in RH6 so I don’t see why it would be referenced. Legacy?
It’s surprising in that sense, though, that the search brings up the result that you link to.
Infers that I didn’t know that. :slight_smile:
Sorry, No. There won’t be any future updates of the Rhino 5 Help. Development has pretty much stopped on Rhino 5. We don’t usually continue updating the Help when development stops on a version.
And yes, the ApplyCurvePiping, ApplyDisplacement, ApplyEdgeSoftening, and ApplyShutlining in Rhino 6 are object properties. You can still type the commands, but they don’t auto-complete.
