Picture frame in latest build 10/18/2016 image on backface instead of frontfacing (direction of normals).
Hi Bill - I see that in wireframe views - thanks, we’ll fix it. Should be both sides. Hm. I see that the image does show correctly inside the Dir command…
https://mcneel.myjetbrains.com/youtrack/issue/RH-35968
Hi Pascal, You might check the fullscreen mode too. It doesn’t hide the menus I have docked on the side.
Hi Pascal,
The same issue with the image on backface applies to textures. If I add transparency to a texture the image doesn’t show up on front faces in orthogonal views. If I flip the surface direction the image shows up.
Bill
