Display buggy - backfaces not shown
I like to send my client screenshots of the rendered view, but backfaces are not shown. Often it’s a big problem for mesh objects.
I asked here, but maybe the thread is to old to get answer.
http://discourse.mcneel.com/t/problem-with-backface-of-surfaces/15750
Is a solution on the way?
Ciao,
Micha
Check first if it is turned off in the displaymode.
I often set backfaces to a different color when modelling.
For mesh objects, you can use the UnifyMeshNormals command to get the facets all pointing the same direction.
Backface settings are set to “use front face setting”.
The unifymeshnormals can help is some cases. But it could be nice to get the display full working.
