in render view, the back faces dont show transparency.
any solution for this?
Hello- how does the full rendering or raytraced viewport look?
very different, but I still wonder why would render viewport does that.
attached rhino file as well
Transperancy on back faces .3dm (369.8 KB)
Hi Mikele - to accurately show refraction the scene really needs to be raytraced - the ‘rendered’ viewport is a fast and ‘cheap’ approximation that is the least satisfactory when transparent, refractive materials are in the scene.
Well, now i see its also on picture frame import,
seems something changed, as in the past (like a couple days ago, also any picture I dropped in, you could see it from both sides, but now one side is gray, even is shaded viewport
Picture frame import.3dm (537.1 KB)
Hi Mikele - can you please run SystemInfo in Rhino and copy/paste the results here?
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Commercial, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Ti (NVidia) Memory: 12GB, Driver date: 8-5-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.68
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-5-2021
Driver Version: 30.0.14.7168
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\MIKELE\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\xShoe4Rhino (0a7df154-1896-4d30-872d-b50fec009da4)\4.2.2022.301\Rhino 7\xShoe4Rhino.rhp “xShoe4Rhino” 4.2.2022.301
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\MIKELE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\MIKELE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\MIKELE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.2\Substance.Win.rhp “SubstanceImporter” 2.0.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
And so seems its applying color/texture now, only on one normal face direction,
im used to it applying on both sides as default.
how do I fix that?
Hi Mikele - even thought it might seem un-related, I would test by disabling the X Shoe plug-in in Options > Plug-ins page then close and re-start Rhino - is that any different?
still same issue, and i have all plugins for a while now, so not sure how that suddenly changed how materials only apply to one side of face as default
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
Hi Mikele - can you please post an example file that looks incorrect to you, or send to tech@mcneel.com with a link back here in your comments?
