when creating a picture frame I often have the problem that the image appears in very low resolution. Is there a way to increase the resolution of the displayed image? I wanted to take measurements of scanned blueprints (the scans are very high quality in jpg format), but the resolution is really bad if loaded in Rhino.
Hi Thorst- I think beyond a certain size, Rhino resamples large images to display them - My understanding is that this is much more efficient if the image is sized to a power of 2, even if this involves adding a margin or cropping (slightly) . So, making your image 4096 by 4096 and then resizing to 2048 by 2048 yourself, or using the full size may look better- that said, your image looks good here as-is, so it may be a matter of graphics support as well.
Wow yes this is just the full information of the original scan. Have you manipulated the image size therefore or was it just how I sent it to you? Can I change any options to get better graphics support of Rhino?
