I can I get a pictureframe with image to go behind what I draw.
I try arrange but if I
- Select the picture frame
- Do Send to Back
I get prompted for an object.
If I do
- Send to back
I cannot select the picture frame.
If I do
Hi Jim - only some things - curves and annotations (including hatches) points and details are eligible for draw order commands. I’d say that should be made clearer in the prompt somehow if possible. I’ll see of we can tune that part up at least. Hmm - it looks like the list of eligible objects is long enough to make a pretty awkward prompt- not sure how to help here…
You can “physically” move the picture frame rearward using Move with the Vertical option. An alternative is to use SetPt
Thanks, that does it.
