I want to create a gradient effect in Y-direction. From the bottom to top the circle should disperse. I used the jitter command but didn’t get the desired output! Thanks in advance!
Perforated screen.gh (16.4 KB)
Is there a way that the circle disperses from the center to the sides?
Thank you soo much!!!
Small thing: In the Sub List component the D input you need to subtract 1, otherwise you duplicate 1 point
Sublist simply chooses a portion of the whole points. It has nothing to do with overlapping points.
It does. You are building a domain out of a list length. If you turn up the density to 1 you now are trying to get a sublist with indexes 0 to list length, meaning you will try to get 1 more point then there are points in the list. That will cause it to reference the first point twice, as you can see here:
You never notice it until you turn your input B up to 1
That’s why you need to subtract 1, so it remains correct even with a value of 1.
I know… If you increase the value to 1.0, that’s not the gradient any more.
Okay. Well it’s actually very nice with the density at 1, so I fixed it for my version. By the way: as always thanks for the super simple implementation. I was already playing around with it and adding more things, that’s when I noticed the small oversight. Small things like this have caused some small bug somewhere later on so many times once the patch starts getting much bigger.
Good idea. Still I think subtracting 1 will be more acurate. If you set density to 0.5 then you get exactly half of the grid points and not half the points plus 1
How to copy-paste/insert images like these on GH canvas?
It’s in File > Save Quick Image. Then enable the preview. But its only overlayed on the screenshot, not the actual Grasshopper canvas.
is it possible inside an uneven curve??
[Perforated screen_re.gh|attachment]Perforated screen_reV3.gh (16.2 KB)
3 years later
No GH file posted. ![]()
3. Attach minimal versions of all the relevant files
