Pen view no transparency for locked objects
Is this a bug? Transparency won’t show up in pen view with locked objects. The highlighted box should be transparent and show the underlying dimensions.
Thank you
I just tested this in Rhino 7 and its not getting a transparency either.
Would SetObjectDisplayMode work for you in this case?
@Japhy good to know! thank you. does not work right now but in the future maybe
There are settings for it, i’ll do some digging.
Ok, silly me. You need to enable the Show hidden lines option, which is off by default in that Display mode.
@Japhy the problem is this would be shown as technical drawing view mode and locked objects even with transparency on will then show as solids. Inverted, that would come closer to what i wanted to achieve. But what I really would like to see is the hidden lines rather dimmed by the overlapping surfaces like it would look like with transparency on.
This gets it a little closer if you Enable the Shade Objects Setting
@Japhy thank you. This one works. So all materials should be in white.
