Hi there,
I’m wondering, when working in shaded mode, is it possible to display a specific object as transparent?
I’m aware of Ghosted mode, but I’d prefer to choose only certain objects to display transparent, like windows on a building for example.
I’ve learned that you can set locked objects to appear transparent, which works ok, but if I try to isolate a different object the locked objects remain visible. I would prefer if there was an object property, (or layer property) which I could use to set an objects transparency. Can this be done?
Thanks,
Joel
