Pen practice
Modelling as practice.
well done!
can you post a wireframe/ shaded view?
Here you go Kyle,
Greetings
-paul
very well done!! thanks for sharing-
Thank you!
i assume you used vray? did you use a regular bumb? the texture looks really good.
No, just rhino renderer. With some small bumps.
nice, you should add cycles in the tags. i went through your portfolio and saw that you used vray so i assumed that. cycles is really a good render, for direct light situations like these, it gets very slow when you try to render big scenes with a lot of indirect illumination bouncing all over. at least in rhino not sure how it actually behaves in its initial main host blender. but we are getting some speed bump here soon i guess :slight_smile:
nice!
Someone did it for me :slight_smile: thanks for the reminder!
