Problem printing PDF Layout
Hi there,
I hope anyone can help me. I try to print a layout with one rendered detail view and two technical views. Quite a mess comes out.
this is how it looks in Rhino:
and this comes out:
Tuesday I need to finish this presentation.
Henk
Hi Henk_Volkers,
Please run the systemInfo command in Rhino and post the results, an example file if possible too please. Thanks.
Hi Japhy,
Thanks for your reaction. I had to bring the file down from more than 30 to 20 MB but the printing problem exist.
20250420 ZItrand en luie trap.3dm (19.8 MB)
systemInfo 20250420.txt (2.3 KB)
Henk
I tried it just to see (only takes a few seconds). I sympathize with printing issues haha!
It seems to print okay on my computer. If you’re able to access another computer or get a friend to print that might be a solution. I’d even see if I could do it for you if you’re able to share the entire file.
I’m using the latest Rhino 8. I think the latest Service Release not latest Release Candidate (I can check it it’s important).
Thanks for your mail. I will try how the file comes out on another computer. When I print as jpg there is no problem. I can work around it for now.
I just found that if I use PDF Architect 9 instead of Rhino PDF the pdf comes out correct. So I solved this for now.
Thanks again, have a nice day!
Henk
