PDF drawing import - no dimension text
dimension text used to import, checkbox “load fonts” is checked
anyone else having problems?
Hi Mark -
That seems to be working fine here. Can you post the pdf file?
4_Lane_Platen_ORing_Channel.3dm (103.3 KB)
4_Lane_Platen_ORing_Channel.PDF (37.2 KB)
Hi Mark -
That text seems to be coming in here:
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05001, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Commercial, build 2022-09-12
License details: Cloud Zoo
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-7-2021 (M-D-Y).
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.39
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-13-2021
Driver Version: 30.0.14.7239
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\UMGE0501\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\UMGE0501\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\UMGE0501\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ProRender\1.0.1.0\ProRender.Windows.rhp “ProRender” 1.0.1.0
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22255.5001
Hi Mark -
That works fine here on 7.24 - could you update to the latest Release Candidate?
Apart from that - I wouldn’t think that it’d do anything but could you disable the 3rd party plug-ins, probably beginning with the SimLab PDF Exporter and restart Rhino?
Also, just to make sure, do you have the “Century Gothic” font installed?
Still a bit of mystery, but once again have text coming thru with imported PDF. Yeah!
Century Gothic was installed
Disabled 3rd party plugin SimLab exporter (that alone didn’t solve)
Uninstalled the SimLab PDF desktop APP and SimLab Composer APP (expired trials)
Uninstalled 3D PDF Maker APP (expired trial)
Updated to 7.23
Thanks for your guidance Wim!
