Help…
i need to simulate a vertical storage (like for rolls carpet…)… i don’t find the solution to synchronize the tubes, i want them on the curve…
All idea is welcome !!..
Thanks a lot for your answers… Can i post an image of what i need ?
Help…
Please post an image, files and final intent.
Welcome Fred,
Looking at your topic’s title I think I see your enigma.
You are using a Simple Constraint (‘To Path’ or ‘LookAlong’) with multiple objects on the same path curve.
The trick is to adjust the parameters of each Object’s Constraint.
In this example Scenobim.3dm (60.7 KB) Object 0 travels from 0.0000 to 0.7536561 (0.7536561 being 1.000 minus 0.2463439) while Object 3 travels from 0.2463439 to 1.0000. Object 1 travels from 0.0821146 to 0.8357707 (again a distance of 75.36561% of the length of the path) etc… Hence each object gets its particular position on the path curve.
The easiest workflow to modify the parameters (in this case) is:
In the keyframeEditor, you’ll see that by using this technique the objects gets additional Position data. This is a bug, … but since the Weight of this data is set to 0.00 it luckily doesn’t have any influence on the actual behavior of the object. Nevertheless I have a habit of deleting this Position data.
Luc
PS To add a picture or sample-file to a topic of this forum, just drag it into the edit window.
Thank you very much for your answer !!
i must bake all before because i do the configuration of the storage with grasshopper at 100%.
I will send to you the result, and please… a little indulgence… it’s my second day with Bongo !..
Thanks a lot and have a nice day !
fred/
