hello all! I’m trying to make a rough flythrough animation via rhino (shaded view, no rendering), and I notice when I record the animation that the back parts of the model seem to disappear. It seems like it has something to do with the depth of the viewing plane. Could anyone provide some help?
same problem since forever!
Hi Liz, Maksym- - so objects are being clipped, is that correct? Can you please post a file (simple, preferably - just a few boxes or something if that shows the problem) with the path curves etc ?
Have you tried the same process in the V6/WIP yet, by the way? Is it any better?
thanks,
I’m having this problem in Rhino 7! When doing a flythough animation on one path curve, the preview play will be perfectly fine, but during the recording my camera’s target gets so close to it’s origin that you cannot see any objects! Maybe it’s a problem with the camera trying to look at the path curve too close instead of keeping the target distance the same throughout?
Hi Joseph -can you post an example file?
Hello! Any updates on how to fix the problem? I am using Rhino 7 now and also having the exact same issues you described as well!!
Hi D L -
Joseph never came back with the example file that was requested. Please provide that and the output of the Rhino SystemInfo command.
I have the same issue. Only half way through the animation the structure slowly reveals itself:
2025-06-04+02_disappearing.3dm (98.9 KB)
I cannot use that. Output of _SystemInfo:
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [92% battery remaining]
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 3-3-2023 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA RTX A2000 12GB (NVidia) Memory: 12GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Users\Felix\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.50414\net7.0-windows\Karamba3D_LicensePlugin_Rhino8.rhp "Karamba3DLicense"
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Hi @feklee
I only see one curve in your file (apart from the “sticks”), so I’m thinking that maybe you are using the same curve for camera and target path? If that’s the case: don’t! It creates a camera with an infinitely short frustum, and this messes up the viewport. Instead, make a copy of the path and move it (in this case) upwards a bit, and use the upper curve as the camera path and the lower curve as the target path.
HTH, Jakob
Edit Ah, you are setting up a fly-through - my mistake
But try what I wrote with the path animation instead. should work!
Thanks for a file, Felix!
I’ve added some information to RH-77918 RecordAnimation clips geometry
Thanks for the suggestion! It’s a bit better as path animation, but the issue is still pronounced:
2025-06-04+02_disappearing_path.3dm (99.3 KB)
In the meantime, I think I’ll do a screen recording of the preview. Maybe I should invest into Bongo.
Thank you!
