I am trying to design a horizontal parametric louver system that curves like a single wave of a sine curve.
Elements to be controlled by the attractor curve:
length of horizontal projection
point of maximum distance from the original line
I attempted this by dividing the horizontal line into multiple points and extruding perpendicular lines which will then be affected by the proximity of the attractor curve.
But I am unable to limit the louver curve at the 2 edges where I want no projection.
I have attached the concept sketch as well as the GH file.
It seems quite hard to calculate the correct coordinates for each point in order to get the curve you want. Instead I would approach it like this:
First make some horizontal planes that give an intersection line with the building, as well as an intersection point with your curve. After that you can either:
Offset the curve to the outside to get the basic louver width, then on top of that construct a curve using endpoints and tangents, connecting the offset line to the curve intersection point
Draw a neat standard sine wave, then transform it (I used rectangle mapping) to a different place and size for each louver.
