Paneling tools bug rhino 8
Having a bug in paneling tools and can’t solve it.
Some components do not work, like convert to diamond.
I get this message:
Scherm­afbeelding 2025-10-17 om 22.44.55
system info:
Syst info.txt (4.9 KB)
I think the problem is in the library, maybe there is some old stuff that doesn’t belong there,
but I’m not sure about what.
In rh 7 it is running still fine.
Hope you can help.
Martin
I don’t think this is a bug, the issue is that the ptToDiamond doesn’t have enough input grids. You need to provide at least two rows of girds in both the U and V directios.
Sorry, I forgot to include the test results from Rhino Mac for your reference.
Thanks Jessesn,
I solved the problem.
The bug was caused by myself, I put all the grasshopper assemblies from Rh7 straight into the Rh8
special folders grasshopper library.
Thanks for your help,
Martin
Hello everyone. my rhino does not pave panel tools. how to get it?
Hi Rauli -
I don’t see any licensing information for you, so I’m not sure which Rhino you are running. Assuming you are looking for “PanelingTools”, you should be able to install the plug-in through the PackageManager.
