Another way
- create ne c# project for rhino gh components,
- add all the c# files to it
- add resources, i.e. icons
Another way
Thanks a lot. Actually, I tried another way. I went to Project Property and changed the “Target framework” to “.NET Framework 4.8” and the problems were fixed. The code was built. The only problem is that when I built the code, I only got a .pdb file, not a .gh file. Could you please check the image below and tell me, is there still a problem in the building process?
Under properties build change directory
Check the 4th last line in your screenshot
Thank you so much for all your help.
