Has anyone had any luck writing ETO forms with charts using OxyPlot or some other charting library?
Did/Does it work both on Mac and Windows?
kind regards,
Arthur
kind regards,
Arthur
I have used Eto worth OxyPlot, however only on Windows and not in rhino, but in a standalone application.
You will need this package
Thanks for the suggestion. I’m finding the compatibility issues between myriad libraries and different versions of those libraries to be pretty labyrinthine… but before I try and sort that out, I wanted to make sure it was even a possibility.
Arthur
As you see in the NuGet page, the package is already 2 years old and references an even older version of OxyPlot (2014.*).
If you want to use a newer version of OxyPlot you will have to code your own Eto.Oxyplot
AND Eto.OxyPlot.Wpf
replacement. I have done this for my project, so if you need such a replacement I can share the code.
Interesting. What about compatibility with the version of ETO that Rhino 6 references?
Arthur
I don’t know tbh, but I don’t expect problems.
