Maybe @nathanletwory knows all tricks - is it possible to create outline renderings per Rhino renderer now?
A client want to get rendered outlines of a scene with an animated clipping plane. My favorite render tool V-Ray fails with outlines and so I ask could the Rhino render tools be used?
just activate the Surface edges in the post effects in the render window.
if you render in the viewport activate them in the viewport settings, or make a new raytraced display mode with surface edges turned on.
@nathanletwory Some weeks before I got a cycles plugin error during the Rhino start and the plugin was disabled. Today I updated Rhino and tried to enable Cycles but still I donât get them working:
Error occurred loading plug-in
Details:
The type initializer for âRhinoCyclesCore.Core.RcCoreâ threw an exception.
RhinoCyclesCore
at RhinoCyclesCore.Core.RcCore.get_It()
at RhinoCycles.Plugin.OnLoad(String& errorMessage)
at Rhino.PlugIns.PlugIn.InternalOnLoad(Int32 pluginSerialNumber)
Rhino Render and Raytraced use the same Cycles engine. The only difference is Rhino Render renders into the render window, Raytraced into the viewport.
Not sure, lines, fills, hatches, annotations, texts and curves arenât rendered by Raytraced, they are done by whatever the display pipeline does.
If there is a difference between Raytraced and Rhino Render then for now you can use _ViewCaptureToFile or _ViewCaptureToClipboard
Not at the moment
if you mean same between Raytraced and Rhino Render then for the parts that RhinoCycles does yes. If you mean Rendered mode - there will be differences, like currently RhinoCycles doesnât support clipping plane participation.
In Windows settings go to installed applications and find Rhino, then click on the dots and choose Modify. That should start the Rhino installer for your currently installed version and you can from this choose to do a repair
Interesting, I had expected that installing an update would also repair it at the same time. But this was not the case and a repeated start of the installer with âRepairâ brought Cycles back.
What I also noticed on this occasion - a possibility to overwrite all materials with a global material is also very useful. Maybe you can add it. In addition, it is practical to deactivate overwriting for individual materials.
