As in topic, When hiitting the render buttun nothing happens. Render does not start.
For Rhino Render it is ok.
I have just now a pull request with a fix running. You’ll have to wait for the next Rhino WIP to be able to run the _Render command with Cycles for Rhino again.
/Nathan
Thank you.
Just getting started with cycles. Ray Trace working fine but still no render button?
Using latest WIP - is this still waiting to be fixed?
Cheers!
No. The cycles render engine will only be available as a display mode in Rhino 6 (the Raytraced mode).
There are several posts with more information on this. Here is just one example:
OK,
Thanks for the info. Will read posts you have linked!
