OptionsExport does not export setting
The setting “Use command options dialog” is not saved through _OptionsExport.
  1. Enable/check “Use command options dialog” within Settings → General → Command Window.
  2. Export all your settings with _OptionsExport.
  3. Reset Rhino with command _Reset.
  4. Import your settings with _OptionsImport.
The “Use command options dialog” is now disabled/unchecked. It should be enabled.
Thanks for your feedback, I think this is a bug. I made a YT for it and was waiting for our engineers to fix it.
