Opening older versions of Rhino in R7 disrupts TEXT blocks! This is for me a drama! I got hundreds of 2D drawings with Title Block’s created in previous version of Rhino. So please FIX this, needles to say it’s a hell of a job to correct every Title Block on opening a pervious version.
Hi @pgerritsen -
Thank you for the screenshot illustrating the problem. I’d like to attempt to reproduce the problem here so that I can log a bug. Can you please provide the Rhino 5 file you used in your illustration?
-Dan
It’s uploaded via Rhino - Upload to Support.
Peter
Thank you for providing the file and the clear explanation. I’ve filed this here:
RH-62783 Opening older Rhino 3dm version in Rhino 7 causes text block change
The file you provided is attached to that bug track item because it so clearly illustrates the problem, but is hidden from all but developer eyes.
