chris27
(Chris)
October 28, 2021, 4:52pm
1
Hi there.
I’m running Rhino 7 (7.9.21222.15002) on my Macbok Pro - M1 16MB Big Sur.
I have a drawing that contains 300 blocks and the overall file size is currently 140mb. It is constantly sticking and/or running very slow in either wire frame or rendered.
Is there anything I can or should be doing to get this to run better?
Thank you.
CF
pascal
(Pascal Golay)
October 28, 2021, 5:02pm
2
Hi Chris - the first thing to do is update to the current service release, sr-11 and see if that makes any difference.
https://www.rhino3d.com/download/rhino-for-mac/7/latest
chris27
(Chris)
October 28, 2021, 5:25pm
3
Hi Pascal.
Thank you for the link for the new release. I’ve downloaded and keep receiving this message: “the operation can’t be completed because you don’t have permission to access “Rhino 7”.”
It also appears to have deleted my current version of Rhino 7.
Any idea why I am getting this message?
CF
pascal
(Pascal Golay)
October 28, 2021, 6:16pm
4
Hello - please reainstall the previous version and run the SystemInfo command and copy/paste the entire output here.
chris27
(Chris)
October 28, 2021, 6:40pm
5
I’m not able to download a previous version as Rhino 6 is not supported. I am however able to open Rhino 7 by over riding my system security. However I can not save the application to my hard drive.
Below the system info requested. I look forward to your help with a solution.
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09002, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Commercial, build 2021-10-20
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.6 (Build 20G165) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro17,1
Language: en-US (MacOS default)
Apple M1 (OpenGL ver:4.1 Metal - 71.7.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1
Displays: Unknown (227dpi 2x)
Graphics processors
Apple M1
Color LCD (1280 x 800 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/libexec/rosetta/runtime
/Library/Apple/usr/libexec/oah/libRosettaRuntime
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp/Contents/MacOS/NamedSnapshots
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp/Contents/MacOS/AnimationTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp/Contents/MacOS/CreaseAngle
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Displacement.rhp/Contents/MacOS/Displacement
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_3DS.rhp/Contents/MacOS/export_3DS
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_3MF.rhp/Contents/MacOS/export_3MF
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp/Contents/MacOS/export_ACAD
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_AI.rhp/Contents/MacOS/export_AI
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_CD.rhp/Contents/MacOS/Export_CD
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp/Contents/MacOS/Export_CSV
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_FBX.rhp/Contents/MacOS/export_FBX
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp/Contents/MacOS/Export_GTS
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_LWO.rhp/Contents/MacOS/export_LWO
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_Points.rhp/Contents/MacOS/export_Points
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_POV.rhp/Contents/MacOS/Export_POV
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp/Contents/MacOS/Export_RAW
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp/Contents/MacOS/Export_RIB
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SAT.rhp/Contents/MacOS/export_SAT
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SKP.rhp/Contents/MacOS/export_SKP
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SLC.rhp/Contents/MacOS/export_SLC
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_STEP.rhp/Contents/MacOS/export_STEP
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_STL.rhp/Contents/MacOS/export_STL
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp/Contents/MacOS/Export_UDO
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_VDA.rhp/Contents/MacOS/export_VDA
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_VRML.rhp/Contents/MacOS/export_VRML
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp/Contents/MacOS/Export_WAMIT
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_X.rhp/Contents/MacOS/Export_X
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp/Contents/MacOS/Export_X_T
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp/Contents/MacOS/Export_XGL
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/IgesCoreLib.rhp/Contents/MacOS/IgesCoreLib
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_3MF.rhp/Contents/MacOS/import_3MF
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp/Contents/MacOS/import_ACAD
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp/Contents/MacOS/Import_DGN
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_FBX.rhp/Contents/MacOS/import_FBX
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp/Contents/MacOS/Import_GTS
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_IGES.rhp/Contents/MacOS/import_IGES
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_LWO.rhp/Contents/MacOS/import_LWO
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_M.rhp/Contents/MacOS/Import_M
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp/Contents/MacOS/Import_OFF
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_PDF.rhp/Contents/MacOS/import_PDF
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_PLY.rhp/Contents/MacOS/import_PLY
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_Points.rhp/Contents/MacOS/import_Points
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_RAW.rhp/Contents/MacOS/import_RAW
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_SKP.rhp/Contents/MacOS/import_SKP
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp/Contents/MacOS/Import_SLC
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp/Contents/MacOS/Import_SolidWorks
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_STEP.rhp/Contents/MacOS/import_STEP
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_STL.rhp/Contents/MacOS/import_STL
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_VDA.rhp/Contents/MacOS/import_VDA
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_VRML.rhp/Contents/MacOS/import_VRML
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp/Contents/MacOS/Import_WAMIT
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_X.rhp/Contents/MacOS/Import_X
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp/Contents/MacOS/MeshFromPoints
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MeshTools.rhp/Contents/MacOS/MeshTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MPlane.rhp/Contents/MacOS/MPlane
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp/Contents/MacOS/NamedPositions
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp/Contents/MacOS/PanelingTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp/Contents/MacOS/RhinoBonusTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp/Contents/MacOS/RhinoLabsTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp/Contents/MacOS/RhinoRender
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/SolidTools.rhp/Contents/MacOS/SolidTools
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Squish.rhp/Contents/MacOS/Squish
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.11.21293.1002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.11.21293.9002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.11.21293.1002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.11.21293.1002
/private/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.11.21293.1002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.11.21293.9002
/var/folders/pv/jqyj3vbs2_bfzkg3wtzsg9940000gn/T/AppTranslocation/F0B8C2E6-8174-41C6-BB0A-69F377C9126D/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.11.21293.9002
pascal
(Pascal Golay)
October 28, 2021, 7:07pm
6
@John_Brock - any idea about why this might be failing?
John_Brock
(John Brock)
October 28, 2021, 7:12pm
7
Maybe this is the same problem:
I have a client reporting the same thing today - any solution?
[image]
John_Brock
(John Brock)
October 28, 2021, 7:16pm
9
Sadly, it looks like a rights issue and Apple is recommending reimaging the system.
I thought this sort of thing never happened on Macs…
dan
(Dan)
October 28, 2021, 8:04pm
11
I would recommend doing two things first:
If those two things do not work, please attempt to copy the Rhino 7.app to your Desktop (drag it to your Desktop instead of the Applications folder) and see if it is allowed to be copied there.
chris27
(Chris)
October 29, 2021, 1:09am
12
Hi Dan.
Appreciate the help and ideas. I have tried all three in order and unfortunately I’m still having the same error message.
I’m now starting to think this has something to do with the fact I have not been able to upgrade my version. Every time I tried I got an error message after the upgrade downloaded. That is in line to the protocol here.
Anyone have any other suggestions to get the latest Rhino 7 for mac to work?
Thank you.
Chris
dan
(Dan)
November 2, 2021, 10:08pm
13
I’m consolidating these duplicate topics over in this one:
does anyone knows why I get this error on my mac (Big sur), trying to install the Trailversion of Rhino 7?
See the picture (it´s german, means in english: The action could not be completed because you do not have the necessary access rights for “Rhino 7”.
Thanks!
[Bildschirmfoto 2021-10-23 um 14.09.46]
