Hi I was wondering if there is a way to access model information (walls,generic model etc.) without having the view open. I know it’s possible if the view is open but not active.
Another question is about the possibility of opening multiple views coming from a list in Grasshopper.
From the screenshot I get the list of all of the views that I want to work with I was wondering if, instead of opening the views manually, there is a more efficient way to do it.
Thank you!
Hi Andrew,
I believe there is a feature request for the open views from list, I’ll add your input.
No need to open views to get view elements. Notice on the Floor Plan that it gets view dependent elements such as dimensions.
There are some caveats in getting visible elements in linked documents. Solved: Get Only Visible Elements in Linked Documents - Autodesk Community
