Have someone an idea why its not working?
Hey,
Internalize your data and share your gh file. And explain little more about your issue.
Cheers,
BVR
I want to loft the scaled Voronoi cells but only some get filled with a surface. The most remain empty.
Surface.3dm (198.0 KB)
voronoi_brep_surface.gh (33.4 KB)
I found out. Thanks anyway.
You could use mesh and surface morph method from 2d geometries. And there are other topics that are similar to yours by resolving the same problem with slightly different method not using 2d…
voronoi_brep_surface_re.gh (111.0 KB)
