Online help - language switchers
Hi All,
for each language in which Rhino is distributed, could you not add a button to choose/change to the desired language on the help site?
you are talking about online help ?
…as a workaround you can edit the address in you browser …
en-us
de-de
https://docs.mcneel.com/rhino/8/help/de-de/index.htm#commands/bridge.htm
https://docs.mcneel.com/rhino/8/help/en-us/index.htm#commands/bridge.htm
but it looks like this workaround is buggy… you might loose the navigation
see this topic also
maybe edit the tile of your post / topic - something like “Online help - language switchers”
yes that’s what i do
in fact, it didn’t happen before.
but now that’s what’s happening to me lately.
However, a button to switch between languages ​​without having to manually change the address would be useful.
see this topic
make sure to insert / not to loose the part of the address:
index.htm#
ok thanks @Tom_P
it works like this, I didn’t know there were two addresses with and without navigator :+1:
let’s say that at this point the problem remains anyway, that is when I press F1 in Rh in English,
it gives me a different address than the one you posted, the strange thing is that in English the navigator is there, if I manually change the language in this case I lose it.
(It’s a bit of a convoluted thing, hopefully we can unify and simplify everything)
that s the bug I reported on the other thread / topic.
@0904
I added a wish report about the language switcher. Thank you.
RH-84167 Help: Add language switches to the website
