Hello, I use Rhino in English, but it’s more convenient to have help in my native language.
Currently, if I am in French, I can search for the term “Courbe” or “_Curve”, the result in these 2 cases is a Fr page.
But if I’m in English, I can only search for “Curve” and the result is in English.
In fact, and not just for the help panel, the “_” character can be used to switch between two different languages, even if the user interface is in English.
In all cases, have the possibility to define the search URL of the help panel and an alias table (EN → lang 2, “Curve” → “_Courbe”) to be useful
Yes, I am using the site.
There is a limit, you have to know the translation of the name of the command.
Sometimes I don’t know or I can’t deduce it. I therefore cannot find it in the online help.
Research such as:
http://docs.mcneel.com/rhino/7/help/fr-fr/index.htm#search-_curve
or
http://docs.mcneel.com/rhino/7/help/fr-fr/index.htm#search-curve
produces zero results.
The help panels in Rhino have additional functionality. The search bar converts name aliases.
It is therefore possible to do the search “_Curve” if the interface is not in English.
In my case, I have the Rhino interface in English, and I would like to read the documentation in another language.
I actually use this in the opposite manner - I normally work in English, but I sometimes need to teach in French and German with the Rhino interface in that language. When I need to launch a command that has a localized command name that I can’t remember (or never learned), I type the command in English with the underscore to launch it, then I press F1. That gets me the online help in the language that Rhino is running in with the localized name of the command. Very handy (for me).
