I would like to make a sister thread to
https://discourse.mcneel.com/t/subd-symmetry/75741/18
I am very excited about subD modeling, but I have to be able to model symmetrically for it to work.
Per Brian Gillespie
"Symmetrical modeling has been on the wishlist for as long as Rhino has existed. The addition of SubD is not going to come with symmetry tools, as any creation of symmetrical modeling also would apply to curves, surfaces, etc.
Our goals for SubD in Rhino 7 is to add support for creation and editing of this new geometry type. Symmetrical creation and editing is not in the scope for V7."
I understand a decision has been made, but I hope you will review this nonetheless. Mcneel seems to be willing to listen to hostile complaints on this forum, so I hope you will consider a courteous one, even if it has already been answered.
For reference
Rhino Symmetry that already exists for lines and edges
http://docs.mcneel.com/rhino/5/help/en-us/commands/symmetry.htm
How I would love to be able to Set up a Rhino SubD to work.
https://youtu.be/dvF34uSp2Mg?t=181
I am modeling plants for historic buildings. I am using mesh2surface for reverse engineering the existing components, and I am using Subd geometry to āquicklyā imagine the pieces that broke.
In order to create an organic shape in a meaningful but quick way, I am deforming a surface, and in order to āforceā symmetry I am grabbing SubD surfaces or points, and moving them or scaling them with the gumball tool over my imagined symmetry plane.
are there any other work around options to achiece similar results?
Is there another method that might work faster (mirrored block instances)?
or other strategies that might make a feasible replacement for a dedicated symmetry mode?
In the next v7 WIP that will come out you can try MergeFaces, Delete on a sub-object edge or vert, automatic hole filling with 3Dface > Patch and GH will have some subd components in the Surface tab. Some other tools/workflows you may have missed are Bridge to span gaps, QuadRemesh for conversion of NURBS Breps to subd with symmetrical quad layout (Iāll post a video of this in another thread as itās got crazy potential), Cap support for planar holes and Pipe support for subd with quad caps. Iāve also found the Dendro GH add-on for voxels to work awesome with QuadRemesh > ToSubd (another video needed there for sure).
