Hello
I’m using Rhino 7.
The shadow disappears after executing the command regarding One Day Sun Animation.
May I know the reason?
I apologize, in advance, if there are any grammatical or spelling mistakes. No offense is intended.
1day_animation.3dm (268.7 KB)
Hi -
I’m not seeing that here:
Please run the Rhino SystemInfo command and copy-paste the result here.
We are sending you the systeminfo data you requested regarding One Day Sun Animation
Rhino 7 SR14 2022-1-4 (Rhino 7, 7.14.22004.01001, Git hash:master @ e3d354475c9d642213575609786a4b35ea48ca22)
License type: 상업용, build 2022-01-04
License details: Cloud Zoo
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
Integrated accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22004.1001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22004.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22004.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22004.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22004.1001
Hello- the only thing I can see off habd that might help is to disable VRay in Options > Plug-ins page and then close and restart Rhino - does that make any difference?
Hello Pascal!
As I worked in the way you mentioned, I was able to produce normal results.
Thank you.
It would be better if we could find the ultimate solution, but we are lucky to solve the problem first.
This is because there was a work that had to be delivered urgently.
Hello- if blocking Vray fixes things, make sure to have the most current Vray and contant their support forum to let them know there is a problem.
We need to think about updating for smooth work in the future.
Thank you for your advice.
