hi!!
i want to know why the offsett is not working with this kind of shape, why cannot have 2 curves when i do the offset to the inside.
all the geometry is planar!!!
thanks!!
With just that information you find the answer !!!
Because it is not working
Try to use Clipper plugin, the only drawback is that it outputs just polyline.
Clipper is a 2D polygon Clipper offering polygon boolean operations (clipping): Intersection, Join, Difference, and robust polygon offsets.
siemen
August 23, 2018, 10:16pm
3
We still need to talk about offset.
Dear Rhino/Grasshopper developers thanks for Rhino 6, many useful improvements, render, Rhinocommon functions … but there is an old subject Polyline Offset see this thread :
Are there some news about Polyline offset ?
I know Clipper is a good solution for Grasshopper and Rhino.
Update : @pascal it is not a Grasshopper question more a Rhino core function. There is a reliability problem with offset Polyline. It doesn’t work on some the cells which are simple polygon (see the picture).
The sa…
