Offset Print Results
Print Results: All text entities are shifted X-1" Y+1" or so. Happens on physical printers and Microsoft PDF printer.
Workaround: Save as V8, and print from V8.
Hi Den -
In a quick test here, the output from Rhino PDF is identical to that from Microsoft PDF and there is no offset of the text object.
Please post both the output from the Rhino SystemInfo command and a 3dm file that shows this behavior on your system.
sysinfo.txt (2.0 KB)
5084-R9.3dm (228.6 KB)
5084-PrintResult.pdf (88.1 KB)
Hi Den -
Thanks for those files.
I’m not getting the offset when I print that here, included when printing to my ancient Lexmark laser printer.
Just to make sure, have you also tried printing with the Rhino PDF printer?
Ok, Tried with Rhino PDF with same results, so I fiddled with some print settings. Bottom of the print dialogue is a section for Text: Notes dropdown was set to Top, so i switched it to None, and then back. Voila - text prints correctly.
I have a few other things to figure out with the print dialoge. Not satisfied with Extents and Scaled to Fit interaction, but I will tinker a bit, and find an optimal setting.
