Serengeti rhino pdf printing glitch
Hello. When I print the file from rhino 8 the print is moved down and cut with part of the bottom on the top. I saved it as rhino 7 and printed it just fine. This was a pdf file that i was asked to add dimensions to.
Pdf import is much better in rhino 8 from what i have tested so far. Thanks/
rhino7.pdf (3.8 MB)
Rhino8.pdf (4.1 MB)
rhino 8 file
Hi Noam -
I’m not seeing that here. Could you post your SystemInfo data and the settings that you use to create the PDF file?
1.7z (147.0 KB)
Thanks
Rhino has a command “SystemInfo” which produces a text file of Rhino and computer related info that Wim would like to see.
Rhino 8 SR0 2023-6-20 (Rhino WIP, 8.0.23171.14305, Git hash:master @ b92f7d293d9a041a6f2cbc4ed304f99aba992c88)
License type: Commercial, build 2023-06-20
License details: Cloud Zoo
Expires on: 2023-08-04
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 4-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.61
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-3-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2023
Driver Version: 31.0.15.3161
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Noam-y\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
printing glitch rhino wip.txt (2.8 KB)
Hello. I updated to the latest version and it seems to work fine now.
Thanks. by the way rhino 8 is much better at opening pdfs than 7.
Peace.
Seeing a similar thing here. If printed via Rhino PDF some lines are missing. The same file works with Print via acrobat or if downgraded into RH7.
layoutPrintFail.3dm (137.2 KB)
layoutPrintFail.pdf (5.2 KB)
layoutPrintFailAcrobat.pdf (6.2 KB)
Hi Phillip -
I see you are on 8.2. Several print bugs were fixed in 8.3 release candidates. I’m not sure if this particular one was fixed in last week’s version, and something went wrong with this week’s version on Windows…
At any rate, your file looks like this here with Rhino PDF:
