Hey, I have been using the divide then offset curve command. I would like the offset to incrementally increase for each of the points on the curve starting from one end to the other. Looks like an amonite. Is this possible?
I have a non-grasshopper solution that might work for you.
Building on that concept, here’s a grasshopper solution. But it doesn’t specifically offset each point if that is a requirement. The input curve is the original swirly curve that you wish to offset.
variable_offset.gh (14.0 KB)
(Edited because it weirdly merged two messages, I think due to some internet issues on my end)
