Hi! Im trying to make a basic table algorithm. For top of the table, I want to offset the curve with different x and y value. But offset curve is giving me only equal value offsetting on x and y direction. How can i make as you can see in the image?
Thank you!
Yes i tried it but scale NU is giving me extension of 2 edges which are x and y. I want to extend 4 edges with spesific numbers like 10 cm extending for 2 opposed edges , the others 2cm extending.
variable_offset_loose.gh (8.5 KB)
This cluser do a “variable” offset loose on a closed polyline, it use a sequence (list) of values for offset distances.
